Supercharger tuners?
So I got the new jeep and she won’t even start…
Since the tune for the supercharger was written for 9000 feet, I am sure part or all of the issue is because of the A/F ratio.
I have a few tricks up my sleeve before I freak out, but in case I run out of ideas does anyone know about, or know of people who are savvy with boosted engines?
The jeep is stuck at my house, so a buddy that can make a house call would be the best kind of resource, but I’m all ears if you know of local places that might be able to answer questions for me.
…fingers crossed it’s just a voltage issue due to ass-hat transporters leaving the lights on for 2000 miles.
Where do you live? I will try making out over soon
By the look of those plugs you have no spark. Check CPS and ASD relay to start.
Is the tuner a piggy back or a flashed ecm?
Sent from my Nexus 6 using Tapatalk
It’s a re-flash of the ecm.
I have ES Tuning in AZ working on getting me a mild base tune to throw on to get it rolling and then datalog it for a real good tune.
Anyone know where I can get some Dyno time if the tuner decides to visit?
I could just WOT pull and get data, but it’s a small island…
Tonight starting at 6pm or so I will be:
  1. disconnecting battery to clear codes and reset ecm from the “pedal down” mode it was in
  2. install fresh base tune that is likely more appropriate for sea level
  3. install new MHR 7 NGK copper core plugs (and re assemble the ignition rail thats stuck under the S/C…)
  4. cross fingers
  5. high-five or punch walls as required
Anyone who wants to hang out is welcome. If all goes well it will be the first firing on this beast outside of high country.
Text me at 401-846-3624 if you want to come by
Perry tuning in Tiverton has a dyno, heard he gets $90/hr
Good lead Jay, thanks.
Don’t have his number but on shove street near Fall River line
There’s a dyno place in Bristol as well:
maximumperformance.biz
Used to hear them all day…
Did it exactly as I said. She fires like a monster now. Also found a vac leak that likely caused the flood start situation in the first place.
Idle is a bit low, and it does need a better tune, but it’s more than adequate to drive around.
Thanks for all the help and tips from you guys here and on the “what did you do today” threads.
S
Update on my issues…
I got a new tune and have been fighting an electrical issue in the meantime.
The jeep runs much nicer. I actually get 120 miles per tank now (up from 103)…
Anyone know why left directional would have my odometer blink? I’ve replaced the multi switch and flasher unit, but no good. One ground wire and repaired due to some chaffing, but that does not seem to be the whole fix. I am targeting G103 next to see if I can improve the ground there.
Anyway, it’s in fighting shape now. I hope to fix the electrical thing in time.
BTW, Buddy Souza in Briston/Warren is the guy for dyno and tune help. He’s not a jeep-only expert, but he’s the best I’ve met around here on tuning issues. He’s an expert on strokers for Jeeps if you are willing to pony up $500 for the serialized software from B+G.
Thanks for all the moral support. See you on the trails!
Buddy owns the place I recommended above!
I heard the dyno runs for a year when I went to IYRS…
I know of him, he’s a Tiverton guy. I heard he’s pretty good
Clockspring issue?
I read about that… more info needed but it’s on my list
Sent from my SM-G920V using Tapatalk
Thread from the dead…
I’m back on the hunt for getting this LJR S/C back in action
9/21 - Transporter friend of mine made it to the tuner in Virginia. It will be assessed Wednesday 9/27
Planned scope of work is to
  1. Measure the spray on the injectors to determine if they are the correct size and % of duty for optimal performance
  2. Swap my SS e-fan controller to not melt when running at dual speed high during high temps and long duration
  3. troubleshoot all sensors to ensure they act according to the ECM commands
  4. write a brand new CAL, Dyno test and road test.
All work is being performed by A2Speed in Collinsville, VA. Dave Kasper is the tech and actually was a Chrysler employee who worked in the unit that developed the computer systems for the TJ and LJ (and Viper and Neon SRT).
These guys are also known as B and G performance. They have a website that shows they perform PCM mail-in service and are an excellent resource for MOPAR computer issues especially in the OBDII years prior to the JK. They also seem to be the HellCat tuner for the stars…
I’ll update this thread with progress to record how it goes.
When this is done, A2Speed/B and G will offer a CAL to be sold with the Magnum Powers supercharger. Anyone who was thinking about a S/C for a 4.0, may want to wait until it’s done because this tune will be virtually plug and play once written.
Day 2…
Jeep is on the operating table.
Dave says the old CAL was not very well written and the ECU shows signs of being “overflashed” which I guess means that there is residual code that has accumulated but maybe doesn’t play well with all the re-programming. He is working on wiping the PCM to begin a total tune from scratch. This sounds good, sounds like a fresh start, but also sounds expensive…
I should know much more next week.
Overflashed? Kinda makes me miss swapping jets and rotating distributors.
Did I mention I hate computers on mechanical things?
I have heard reference of “too many flashes” or " burned up the program slots" but noone seems to be able to tell me much about whether that is a real thing and what exactly it means.
I think I will be speaking to Dave directly about this concept and the state of my PCM, so I hope to have a more definitive answer to what that is all about.
