Over the last year, I noticed my engine losing more and more power. I was told thet this was the original engine, with no rebuilds form the PO, and this was confirmed when we broke it open. It was time for an engine swap. At one point, I was leaning strongly toward a SBC, but as time went on, I decided I wanted something a bit more original. I decided to build a stroker. 4.6L with the MPFI out of an OBD1 Cherokee. Here is how it goes:
Many of the parts had been acquired over the course of a year or so. I think I got the block and head last spring:
Wiring harness and computer from a 94 XJ ( the computer was a brick, or so I found out this past weekend when I tried to start it!)
Crank and rods from my 4.2 (CJ crank on the Left, 4.0 on right)
Mild port job on the head:
Block machined to zero deck with custom dished pistons:
Long block assembled:
Between the rails:
Ready to roll!:
I did quite a bit of research on this before starting the project and it paid off. Everything went pretty much as I expected. It would have been running on Friday, however, I had some issues withe electrical. After checking and re-checking for 2 days, It finally occurred to me that I may have a bad ECM. The person who sold me the harness said it was out of a runner, so I really didn’t consider that to be the issue. Once I got a new ECM, It fired immediately.
I only have about 20 miles or so on it right now, but so far, loving the POWER! Got to get a few hundred or so on the engine, then we can give it a run on the trail.
Thanks to those who helped out with this: Derick, Gene (who also gave me a bunch of parts!), Eric and Roxie; who all helped with the teardown (at least I thought it was Eric…I offered beer and he didn’t take me up on it. Hmmmm)
