Thanks for the quick replies! Why I like on this kit is that everything is compatible and compact size. I find the choices of antennas, fittings, antenna mounts and antenna lines to be confusing. I also like the idea of a tail light mount. Does anyone have that type on antenna mount?
Honestly out of that kit I would go with the Light mount or the tire mount fittings and the wilson 4’ flexible. Use the Flexible as a precaution to what I did by dropping a 102" on another Jeepster during a run.
if your worried about the antenna being to tall go with a spring mount between the antenna and the mount. i really need to pick one of those up for myself. i mounted mine inside of my center council. fit nice but hard to hear.
I do worry about the antenna being to high, my jeep has less than an inch clearance in my garage. With the wilson 4’ flexible antenna do I need the spring?
The Wilson 4’ Flex will be good at times but the mount might strain. I would suggest a spring on any antenna that peaks over the top of your Jeep. My antenna has a 180 degree flex and I still snapped the screw base off of it.
I ended up getting : Firestik R-1a External Locking Quick Disconnect and Cb Radio Antenna Mount and Firestik SS-3H Heavy Duty Stainless Steel Antenna Spring from Amazon. Both products have good reviews and seem well made.
I plan on getting the kit sometime in late January early February. Having the help would be greatly appreciated! I’ll make sure to schedule the install at YOUR convenience!
