I have 32x11.50. I’m getting 33x12.50 you guys think it will fit fine? And my lift is 4.5" Rough Country X series
i’m not an XJ guy but from what i heard you need to do some fender cutting. Here is a good write up on it
you will need to trim your fenders.
Thanks guys
I ran 33s no problem on my xj with the same lift. Just had to cut the fenders
Yeah I already put the 33x12.5 all I hade was to Adj the controle arms, thanks to Mike(YJMike)
And so faar I don’t need to cut
Just wait till you take it out on the next trail ride…
Have you extended the bump stops?
