XJ electric fan
Anyone got there stock electric fan layin around. need one for my sons jeep.
tried to wire ti to turn on with ignition because it wasn’t coming on by itself, but it seems to be dead.
i had same thing went with my wifes after replaceing fan motor twice and a swich that is under pas head light i was told to put a fan clutch from a 2001 318 or 5.2 when i did that ever had a problem again and it is alot cheaper also and takes 10 min to pull out old electic and screw on manaul you sould be able see treads on pully for waterpump that will tell you if you can do that hope this helps
Mine already has clutch fan, but also has electric fan. aftermarket electrics are way too expensive.
Can you send me a pic of the fan you need i have one from a xj im taking of my buggy. 401 406-1512
all fixed found one at the boneyard.
