All vehicles participating in trail ride events must be properly equipped. Required equipment depends on the trail and will be noted within the event announcement. A properly equipped vehicle helps to keep the event moving and is a courtesy to your fellow Jeepers.
The following list shows the type of equipment that may be required with the more commonly required equipment appearing at the top:
Front and rear tow points.
Tow strap without metal hooks.
A transfer case with low range.
Fire extinguisher.
Tires with adequate tread.
Appropriately sized spare tire.
CB radio.
Tire pressure gauge.
Air compressor.
Tools and spare parts.
May 1st, 2013 Adopted by a vote of 22 yes and 0 no.
