I need to borrow the reamer tool to do over the knuckle steering for my one ton set up any one have one I could use
Jamie,
Here is a link to a flip insert… this allows you to drill a straight hole, no reamer needed and do the over the knuckle conversion. Also, they sell the sway bar relocation bracket… This is on my future to do list… The insert is from Kenneth Thompson and the bracket is from Black Magic Brakes. I bought the door hinge repair kit from Kenneth and he has quick turn around.
I have the inserts already but still need to redesign the link mounts.
To do all of what we need to do it would cost more then the tool for inserts.
the reamer is about 65.00 bucks for the right one…fyi I looked at work and could not find one
I have a reamer which I bought for the same conversion this past summer…do you still need it?
I also have the reamer & drill bit, when I did my JCR kit.
