Tire Conundrum
Got a question, and figured this would be the best place to ask. I’m planning my build for
my TJ I have a set of 38x12.5R15s in the garage, but will those fit on my Dana 60 front and 14 Bolt
rear without having to put a crazy backspacing and possible spacer just to clear everything, I have to
purchase the right lug pattern wheel one way or another. Iintend to get larger tires anyways, so that
leads to another question should i sell them now to and speed up the current stage of the build that
much faster and drop the $$$$.$$ after its built? :question: :confused:
I doubt you will be able to fit 15 inch tires on the Chevy Dana 60. My Chevy Dana 44, three-quarter ton version, had the same bolt pattern and calipers as the Dana 60. I had to switch to the halftime calipers, and caliper brackets to get everything to fit. I would assume this would be a similar problem on the Deana 60
And even if you could make them fit a 17"-20" wheel makes more sense for that size tire. Sell.
16" wheel minimum with one ton breaks
Well then, looks like I’ll be selling them. Oh Goody, I can plan in bigger ones now. :slight_smile:
That’s the right attitude!!
You can donate them to a club member :wink:
