Well… after a solid week’s worth of evenings, the Heeps sitting on all fours again!
The install was pretty straight forward. However - taking apart an Aussie locker sucks, and I’m hoping that I never break the shafts 'cuz getting them back out is going to be a nightmare - They seat in TIGHT!
So why the upgrade? - had a shot bearing and seal in the drivers side - yeah sure, it’s doesn’t justify the work, but hey, “while you’ve got it apart…”
The dreaded Aussie locker uninstall -
The pins are the worst, tried with a screwdriver, but couldn’t get enough friction to slide them so I made a “tool”
Here’s the difference… stock Dana 35 on left, stock 8.8 in middle, Super 88 on right.
Getting the pressed in bearings out was a nightmare - ended up cutting the axle tube off (which you have to anyway) ground the edge off a 2.5" washer and got it in behind the bearing and used another “tool” to pull them out.
Here’s the ground off tube:
And what it used to look like -
Next to press on the new bearing seats -
Make sure you grind off the rust before re-assembly -
you can see where the new bearing seat fits -
Here’s why taking it apart isn’t going to be fun - but hopefully I won’t ever need to.
The whole thing should take about a day, but I re-worked my ebrakes and a couple other jobs while I was at it. The only issue I had was that somebody at Superior missed a lug nut hole when they were tapping it out at the factory.
