SSYE
Hey guys I’m planing on doing my super short sye on 4/19. I could use a hand so I don’t screw this up. Some have said you don’t have to take out the TC to do this. I’m very busy this month and April between dance and t-ball and special Olympics. I’m looking at sat befor Easter 4-19. My place or yours. Any help will be appreciated. I don’t think it should take that long when I confirm the date I’ll post up on tech day and I will be buying beer and food if the weather is nice maybe on the BBQ. We can make it a multy tech day if it’s at my house. Let me know thanks.
You don’t HAVE to drop the t-case, but it is so, so much easier if you do and do it on a bench!
i wont do them unless its on a bench
You don’t have to take it out but it will take you longer to do it not out. Which SSYE did you go with? Biggest proble. I had was getting off the pinion nuts with it out. Didn’t have an impact wrench.
Terflex
We have done them on the vehicle but it kind of sucks unless you have a lift. Personally, I would pull the t-case and install the SYE on a bench.
BTW, 4/19 is the day of the Big River clean-up. . .
i need to look at the calender again to see what other days i can do it…i just would like to get it done before go topless…
You definitely need a set of lock ring pliers:
sears.com/craftsman-lock-rin … 947386000P
Without these you could easily find yourself smashing everything in sight with a sledgehammer.
thx i need to see if i still have mine…tools seem to walk away before you need them again.
Lock down the day and I will be there. I have lock ring tool also.
Let me know the day if I am free I will be there
Im free that weekend I cant make the clean up due to work I have mandatory Saturday’s
