OK I got a spare one and put new ujoint in it. Then I realized it doesn’t fit in yj axle. Prob cuz I put a seal near vacuum disconnect opening when I went to one PC shaft. So anyone got one they want to trade for mine with new joint.
Pop off the cover where the actuator used to be.
On the diff side there is an insert there you may need to remove. Check out bleepinjeep’s video
youtu.be/3gY92m1r0U0
youtu.be/RZNmSqfrzug
thats what i was wondering too, but not sure how to remove it?
well took shaft out and that collar is plastic and it popped right out. now i have a spare i can actually use. thanks for the vids
No problem.
I have to do it too. I had just watched those minutes before
