I need one of these to keep my transfer case linkage from slipping out of its mounting bracket. I already checked Gomer Depot and Blowes. Tractor Supply maybe?
The shaft is only 3/8" diameter. Drilling a hole would probably weaken it too much. Besides that, the way it keeps popping out there must be quite a bit of thrust load. I’m not even sure a collar with a set-screw will do the job. I really want one that clamps on. After alot of searching I find that Fastenal is listed as a distributor for a company that makes exactly what I am looking for. Unfortunately, every time I have tried dealing with Fastenal they want to sell me a whole box, not a single item. I’ll see what they say.
Never heard of them. Just checked the website and they have them. Not only that, they have two-piece units so I don’t have to pull the shaft to get it on. Looks like they don’t have a local presence but a great source nonetheless.
So when I reached up under and measured the shaft with a tape measure I got 3/8". What do you think the chances are that the shaft is really 10 mm, which is 0.475 mm larger than 3/8", so when I try to fit a 3/8" collar it will not fit? Guess I better drive home and get an accurate measurement before I click the button. Thanks.
Eric, if you can get an exact measurement, there’s a place near me that carries all sorts of fasteners. I can swing by to see if they have what you need. http://www.aquidneckfasteners.com/1.html
