Does anybody know where i can pickup a replacement for the top shock mount the bracket that goes through the top part of the shock it is the pin with the flat ends on it.It broke.
Thanks Mike,
Are you talking about the pin that slides through the eye of the shock, flattened out on each end?
Yes the pin i plan on getting new shocks but money is a little tight wright now. I need the pin from a old shock maybe i can press it out.I dont want to buy 1 new shock because these skyjacker shocks suck.I plan on replaceing them all when i get the money.I bandade for now.
I might have one, ill look in a bit
It sounds like you are describing a bar pin. I might suggest getting some bar pin eliminators when you get your new shocks.
I might have 2 at the garage. Won’t be able to check until monday though. Working a double tomorrow.
Might be a good time to install a set of these: http://www.quadratec.com/products/16030_101.htm So you don’t snap another.
I will look too, I may have one laying around. Call skyjacker, tell them you need one…maybe they can toss you a freebie in the mail? They sent me new bushing for my steering stabilizer for the bubble.
Mike,
I have your pin, in fact, the whole shock for a 4" lift, if ya need it.
nope mine are gone
Was thinking could we could make 1 ?
but i see that Jay has one
Thanks for all the help.
Jay gave a spare shock to use till i get my new shocks in. ![]()
