Hi all .
'bought my 95 ZJ with the pas. rear door window never worked.
finally found a problem , under the left rear cushion is a 16 pin connector.
some wires were corroded off / that is why the door jam switch never worked , nor the rear cargo light ever came on when opening any door. Got all interior lights to work .
Now, the window has been up all this time , and now I got power to the window , when I press the “down” on the door switch , I hear a “click” every time I press “down” , there is this “click” sound.
There is no “click” when I press “up” / thinking its all the way up and cannot “click” any,more ?
[ Im so close getting this window working ! ]
most of the web sites talks about window switch’s , I removed and cleaned them all .
and no broken wires .
right now I think there are 3 reasons why the window does not work .
- bad window motor
- window is stuck in window track , or some other thing preventing normal operation
- web site says there is a solenoid in a front door ? , but wouldn’t that effect all doors .
Any ideas ?
