par-15
does anybody have some insight on the par-15 for frames? how mush rust do i need to grind off? i have been grinding all day and there is alot of spots i cant get at with out pulling of parts.
I thought you could apply it right over rust? Just a wire brushing is all thats necessary. Be CAREFUL with the application. The only way to get that stuff off is wait for skin cells to regenerate.
just to let ya know it WILL NOT STICK TO NICE CLEAN METAL unless it is preped with there metal prep.u just need to remove the heavy rust then wipe it down to remove any oil /grime.
thx for the replys. just orderd it will see what hapens.
crown sells it in there canton store i believe
Providence Lacquer Supply on Park ave also has POR-15, and all the metal prep solutions in stock
