Hello everyone! I just recently purchased a 1985 CJ7 and was wondering if anyone had any recomendations on who is a reputable mechanic and shop where i can have some stuff costomized like the interior and exhaust. Also wanted have someone look and see if they can help with the “death wobble”. I live in the Exeter area and looking for some recommendations.
Crawl Daddy is in Attleboro
DW in a CJ, i would check tire balance, worn steering components. not much to leaf sprung jeeps imho. i went to Cory’s in Warwick RI. good guy, he’s a race car mechanic
To add to Derick, I would also check and/or repack your front wheel bearings, and check for play in your steering shaft.
All issues I had at one time or another.
When does it shake
It doesnt as much start to shake as it reaaly pulls to the left when it gets rattled.
I would start with checking Tie Rod ends and Bearings for looseness.
you can check the alignment if a tape measure, pm me some time I can give you a hand
I traced my DW to my track bar… Anything that has play can cause it, do not replace or add a steering stabilizer it only masks the real issue… ![]()
You coil spring guys ![]()
No track bars on a CJ! ![]()
