I have a good double u joint shaft I want to use on my xj but did not come with the bolts the go through the yoke at tcase and go into end of drive shaft. Anyone know what size been to autozone and tractor supply nothing it is a weird pitch or something any help would be greatly apprciated thanks
you can try talking to Jeff at Crown automotive or run over to Jeeps Unlimited in Prov. they should have everything you need.
Never have a lot of luck at jeeps but ill check it out thanks man
i’ve got all that ish if you dont mind taking a ride to lamestown
