Rock Hard 4x4 Parts Fuel Tank Breather Skid Plate
quadratec.com/products/12065_3020.htm
Rock Hard 4x4 Parts JK fuel tank EVAP canister shield is easy to install, uses factory holes and bolts and protects the canister from damage on the trail.
$99.99
Perfect for CJ after he replaces his Evap canister.
He might consider relocating it.
I have that same skid. It is a must for any JK on the trail. Relocating it should not be done. First it is illegal in most states including MA and RI. Second, everyone I know that has relocated spent 2-3 times as much for the kit than the skid and every single one has had leaks which trips the check engine light. Leave it alone and put a skid plate under it.
my 2 cents
That skid takes longer to get the tools out to do the job than it takes to do it.
Got one… and glad we have it… it has a few extra dents and scrapes after the Jeep Jamboree! ![]()
