just started yesterday. is it the flex plate / cracked, starter going or need shims, or something with the transmission ??? please dont mind the mess got carpet cleaner sprinkled all over the carpet.
and yes, i need a new sifter plate incert.
did not edit so its kinda sloppy
some times there is noise, some times there is no noise. when I shift from park to drive the noise goes away also noise goes away when driving over 50 and shifts into 4th / RE42
Note: I did over tighten one of the flex plate bolts. now it wont torque up. just gets kinda tight then it spins past being tight. how do I repair a stripped nut on torque converter or could be the bolt. going to remove bolt and check tomorrow
Thanks for your input on this
