Rancho RS5401 Steering Stabilizer - $20 - Used, but in decent shape, needs paint.
Front Bumper Bumpers - $10 - Take all 3. These are the square rubber blocks on the front of the OEM TJ bumper.
Misc Black Shock Boots - $5 - Two of them, not sure what they fit. I can measure if needed.
Chrome TJ Headlight Trim Rings - $5 - Chrome, pretty sweet ![]()
Doorless Mirror - $10 - This is a universal tow mirror or something, maybe 4"x6" on a 8" bar mount. Drop a bolt through the door hinge, and you have a mirror with the doors off.
Black TJ Headlight Guards - $5 - Black. To offset the chrome rings ![]()
TJ Tail Light Lenses - $5 - Take 2. They have a bit of staining on them from a guard or something, but aren’t broken.
Swaybar Disconnects - Sold
Teraflex Transfer Case Shifter - $50 - teraflex.biz/tj-wrangler-shi … apter.html Bought it used because I was having problems with the factory linkage, but repaired it.
JKS Disconnects - $60 - Used these for a while, and was very happy with them. They could stand to have the bushings replaced. One is new, the other 3 are included.
Universal 10" Sway Bar Links - $20 - Never installed these, they didn’t fit the rear of my TJ. Bushing on each end, 10" eye to eye.
Tow Hooks - $10 - Take 2. These are your standard aftermarket hooks, not the square base OEM hooks.
CB stuff - $60 - Cobra 19DX new in box. 3’ Firestick with tuneable tip. TJ tail light mount. Spring mount. You would need to add the coax, and possibly an adapter between the cable/spring. On hold for Mark.
Hella 500FF - $50 - New in box, fog pattern. These are the FF model with the clear lens.
Spiderweb Shade - Sold
Hella Light Covers - $10/set - These are the standard white Hella covers. I have one set that fits the 500 series lights, another that fits the 700.
K&N Filter + Cleaning Kit - $30 - Fits an 04 4.0 TJ, not sure about others. Recharge kit has been used a couple times, should have a couple uses left in it.
Rough Country Flex Joint Rebuild Kits - $20 - Two large joint kits, two small joint kits, the tool. I’ve also got two of the old style small joints with a snap ring on each side. Some extra washers and stuff too.
I’ve got a handful of miscellaneous small parts too. Used trans mount, exhaust hangers, brake caliper rubber boots. Odds and end stuff like that. Free to anyone who is buying anything else.
Everything is located in Riverside, RI. I have pictures of everything, and can text them if you would like, just PM me a phone number of anything you are interested in. I will update the thread with anything sold and anything else that I come across.
Updated sold items. Found a couple extra parts too.
