Driveshaft rebuild
anyone know of a good shop to have a CV driveshaft rebuilt?
Double cardan?
Cockcroft in East Providence does my driveshaft work. They typically turn a job around in half a day.
do it yourself. if you can change an axle ujoint, you can rebuild a cv shaft. get some spicer parts from Crown and i can help you rebuild it this weekend.
but first off, whats it doing that you want it rebuild it?
I have done 2 my self not that hard. Just need a c clamp press and it will be done in 2 hours pending on rust. Lol I have every thing need. You supply parts and I will teach you as well
CV joints on both ends. Got a “new” one from pick n pull but it makes a knocking sound that gets louder with speed. The old shaft was really bad so I am going to check the bearing in the t case when I get time to make sure that is not also a problem.
I will help you diag if you want
my guess is its the centering bearing. just get a new one and an extra ujoint and it will be good as new. it takes longer to pull the shaft and reinstall it then to tear it apart
stu-offroad.com/axle/drivesh … haft-5.htm
or order it from here
dennysdriveshaft.com/p425_sp … eries.html
dennysdriveshaft.com/p1079_j … _cent.html
My shaft does not have any u joints
You can buy them remaned for about $400 but I don’t know if a anyone rebuilds them on site. They make a rebuild kit for the axle end but not sure about the case side.
You might consider converting to Cardan-Double Cardan style driveshaft.
