ill post up more when i figure out how to mount my spare again, im thinking a 3/4" wheel spacer will work… but i thing that it coule be made with 2" bolts rather than 2 1/2" bolts and i think you could mount a spare… the bottom of the jack doesnt hit anything with the gate closed, and when the gate is open, it sits a hair under the tub coner. so right now im thinking that if i use shorter bolts and move the bolts 1/8 to 3/16" down i could mount a spare…but thats just a thoughts right now…
well got some rod couplings to use as spacers over my 1/2" bolts…
and i cut 'em down to 1 1/2"
installed
heres what i used for the first style
using the sleeves let me move the jack about a half inch closer to the tail gate… making it possible to install the spare again… but i still need a spacer
you cant remove the jack without removing the spare…
locking lugnuts used to lock spare and high-lift
another open gate pic
hi-lift base trimmed a little so it cant possibly hit the tub
