Make sure you get the Firestik II which has the tunable tip.
If you are mounting it to the bumper then 3’ will not cut it, especially with a metal top. Wranglers have canvas/fiberglass tops which do not interfere as much as metal.
Thought I ordered a Firestik II but remembered I went with a Firefly instead for the flexibility and being adjustable. Hopefully it will work as well as a II and hold up better.
ah yes, the spring. I snapped my first fire stick, and reordered the second one along with the spring. I think ebay has 2-packs for the antennas for this reason
I have a 102" steel whip. The optimal full Wave-length Antenna is 103.2" or 8.6 feet. That is for channel 20, mid range transmit and receive. if you do anything shorter the antenna should measure within either 1/4, 1/2, 5/8 wavelength. A 3’ firestick would be in the 5/8’s range and being tune-able it will work perfectly.
I have dealt with a snapped 3/4 wavelength antenna on my first car because I didn’t have a spring and I hit a low bridge. Snapped the fiberglass core in half.
I just push the little button and talk to the gunner, then let it go and listen to what he/she has to say! What happens in between the two I have not a clue!
