Cam bolts lower control arms
I went to my local Jeep dealer to get cam bolts for adj lower control arm brackets and after arguing with counter guy that I didn’t have a vin # he looked up part and said backordered lol. So doe anybody know where I can get cam “d” bolts for 93-98 gand or 97-06 wrangler they are the bolts that bolt the front axle to lower control arm. With washers with off center holes. Thanks
send a PM to Crown Automotive- Jeff. he should be able to help you out. you should be able to find him in the PM contacts list.
I’m not sure he checks PM regularly. His number is 877 298 5337.
Prepare yourself for sticker shock. These bolts are like $25 each or someting crazy like that.
he gets an email that he received a PM. he’s also on NEJZ site a bunch too
Ok I’ll give him a call or something thanks. I’m going to tack weld in few spots for now should be good for while.
I have a set that I ordered and took out once I went to adjustable arms. $20 and they are yours, I just have to pick them up from my parent’s house down in Bristol.
Ok let be know.
jim are these for the xj? if so you problibly dont need them irc you have a long arm kit that should have ajustment on one side of he suspension link. i would look into getting lca brackets that get rid of the cam bolt.
^ Another good option. Its easier to dial in the caster with the cam bolts and that is why I kept mine when I put new brackets on my axle. But if I did it again, I would ditch the cam bolts.
That’s why I did it also … But now that I know. Lol
I am down in Bristol now and checked the garage, I tossed them in my truck so I’ll have them with me. Send me a PM and let me know what works for you, if you want to meet up or have me mail them.
Sent them out today for you Jim, they said that you should probably see them Monday.
Thanks
