So driving down street and boom! Motor mount broke broke all 3 bolts that go to block gonna have to easy out them out just don’t got enough of bolt left to know the size to get gonna get grade 8 but need to know size if anyone would be willing to tell me the size would help a lot it is the pass side mount on a 95 cherokee 4.0 the one on the block thanks got to get it done this weekend need it for work this sunday
take a bolt of the drivers side for sizing up
Ill try did not know if they were different lengths but if anyone knows or can lend a hand Sunday let me know thanks
If you want to keep it from happening again —> http://browndogindustries.com/S2572RE-Jeep-I6-Engine-Super-Bracket-Right.aspx
You should be fine just to replace the bolts. Its common for the 95 to break them.
From what i have seen they are the same size bolts. I would go with grade 8 or higher bolts.
Ya looked at it looks nicie got to get the money guess the sye will have to wait
Just got to find a easyout set to use tomorrow and figure out how to use them never used a set before. Got new bolts allready just going to put stock on for now till I get the new one… anyone have a set I can use or that would be wjilling to help tomorrow ill buy the beer??
Here is a pic any sugestions??
If you get your hands on an easy out, let me know. I have 1 or 2 zerk fittings that broke off and need to be removed lol
I cant see your pic but is there enuf of the bolts sticking out you could plug weld a nut on the end of the bolt? Then use a wrench to turn them out…
looks like you might be able to
Looks like heat and vice grips might do the trick. . .
Thanks for all the help let you know how it goes and hope to make it to next meetin.g and ru.n let. Me know again when they are when u get a min.
Soon to be member - brian
Check the events forum. There is always something going on.
So got new bolts in ans riding fine for now but does anyone know of a good bracket like brown dog but not the much $ let me know if not gonna have to go with them just seeing what’s out there
