Looking for brake line extension brackets for 2011 JKU with 2" OME lift.
Wondering if anyone has some they want to get rid of if not using anymore.
not sure if its the same with JK’s but on my TJ i just drilled a new bolt hole an inch or so under the existing.
Great Idea. I will need to do some planning. Mine has a tab that is bent into an opening in the frame. I need to flatten it out and then put two holes in it.
Again great Idea.
Thanks much.
Brian
i cant claim i came up with it but it worked for me.
