To all you fellow part hoarders out there:
Looking for a junk AX15 trans, I need the rear extension housing off of one.
ebay.com/itm/264443745641?m … media=COPY
Sent from my LE2127 using Tapatalk
Wrong end, that’s the bell housing at the front
Ohh
All set, found one.
did it rot out in you ??? Mine did.
No, several stress cracks in the aluminum. I need to redesign the crossmember I made, seems to be a bit to rigid.
