need a good head for coil style engine. 2002 TJ
TJ has a cracked head and WJ engine blew last night.
Any leads on a good reman one that is local would also be appreciated.
Paul Remillard, has a 4.0 engine the last time I checked. You can shoot him a message see if he still has it : 16175436783
Sent from my SM-G955U using Tapatalk
You can use the older style head(which is more reliable)you just need to make brackets to bolt the coil to the valve cover bots.
