Hi guys. Wondering if anyone has any insight on my jeep not starting.
It happened out of no where, was working fine, parked it, go out, 2 minutes later got back in and it wouldn’t Start.
It’s not turning over.
Starter isn’t clicking.
I tried starting in 4lo because in the past is had a clutch position switch issue and that did nothing
Tried taking out a couple switches people recommendded online.
Battery is newish but all lights on dash come on and headlights work fine, don’t think it’s that
Ended up push starting it to get to a buddies c
Garage and we’re gonna read the obd port soon and hopefully that gives us something.
I would appreciate any help you guys can give! Thanks!
Check battery terminals and scour them well. I had the same issue with a newer battery and I found I could jump the Jeep if I put the cable on the red wire and black post, but in no other combo.
There was a good amount of buildup between the post and the wire socket. you can borrow a special wire brush from the auto part places if you need to. Remember to scour the post and the inside of the wire that connects to the post
I would check this first just because it is so easy and common.
That was what my problem was not long ago. And here I was thinking for months that my battery was shitting out. Turned out the starter was the issue from the get go.
Always a good feeling to figure out what the issue is
