1977 F-150 Dana 44 High Pinion with disc brakes, 66 1/8" WMS, has new Yukon 4.88 gears, new Dana Spicer carrier, new Timkin bearings, New inner seals “these are the smaller OD ones, the 78 and 79 use a larger Outside Diameter ones” , new pinion Yoke, pinion seal, Dana Spicer 5-760X U joints, Spindle bearing kits, inner and outer wheel bearings, brake pads, brake rotors, remanufactured brake calipers, Warn premium lockouts, and new differential cover.
This is from the same guy who build Jays (Freejeep) dana 44.
$600 is the asking price and that is a steal. Truss from TNT or Artec and you are good to go.
