yoke
I need a yoke for my output shaft in the front for a double cardon cherokee shaft. What would i take it off or does anyone have one
You answered your own question lol an xj with a 231
my TJ 231 has the same yoke as well
Just didnt know if a 6 cyl was same lol
I have noticed that there are some differences in the output yokes for 231’s. When I replaced my t-case a couple months back I ended up using the front output yoke from the broken case on the new case. Turns out the yoke from the broken case was a little shorter and did not seal properly.
Make sure your new yoke slides far enough inside the seal.
I just used the whole tcase from an xj lol
