XJ with no Doors?
Any one know how or have been able to find a good way to remove the doors on an XJ?
Sawzall :smiling_imp:
From what I have seen depending on the year there is wire disconects either in the door (remove speaker) or in the kick panel. Then its a matter of unbolting the doors.
If you take a look on NAXJA.org there are a bunch of write ups for both 96 and down as well as 97 and up. I have done this mod to my Jeep and love it.
Ok cool, Thanks guys!
you guys think this is a good write up?
jeepforum.com/forum/f11/remo … up-408138/
It all depends on what you feel comfortable doing and if you understand what you will need to do. I’m not familiar with the new style door hinges, but taking a brief look at the write up it seems that he shows everything you would need to do.
K, cool!
wouldn’t have this problem if you had a wrangler! :smiling_imp: :smiling_imp: :smiling_imp:
When I had my XJ I just cut all the pins and bolted them in. Sure it wasnt as easy as removing the doors on a wrangler but it worked.
