XJ front skid and high lift
First item is a front skid plate for an XJ, it was on my 96 but I’m sure it will fit the new body styles as well. $45 I have the hardware to bolt it up as well.
Second item is my high lift, works fine even with the bend in it, and I’m sure if you put between two hard spot you can straighten it out. Reason for selling it is, decided that I need to go up to a 60" one. $40.
how much for the high lift
$40
high lift is sold.
