WANTED: Drivers side D30 shaft and stub shaft washers
I’m looking for a pair of those huge washers that go under the 36 mm nut holding the stub shaft onto the unit bearing. Crown carries the nuts but not the washers.
I’m also looking for a drivers side D30 axle shaft to carry as a spare.
ahh too bad. i just dropped off my spare axle to get my core charge back. i might have one or two sitting around in the shed
I have a shaft for you. It’s the weaker u-joint though. I also have the washer as well, but you will have to figure out how to get the nut off first.
I should have mentioned that I’m looking for something that fits the 760x joint.
