torque specs
Does anyone know what the specs are on the u-bolts for the 8.8? Does 80ft. lbs. sound about right?
I cranked mine to 140… maxed out my torque bar… BUT… I’ve got 9/16th’s bolts and deep nuts too.
(that may be too much personal information)
Holy crap! Most forums I’ve been on say between 60 and 90. I torqued my D35 at 90 and it twisted the heck out of the u-bolts.
the torque specs would be for the u-bolt size, not the axle.
jeepsunlimited.com/forums/sh … =SYE+write
Yeah, I had them made up at Palmer Spring. Wanted to get them done right so I got “extra beefy”. That’s the specs I got for the size and thread.
Def don’t want to torque 1/2 inch anything over 80-90lbs.
Wise guy!
The bolts that I twisted were made at Palmer spring and they told me to go 90 ft.lbs. I’d say it was a bit too much. The bolts I will be using are half inch thick (same as Palmers) and I don’t want to twist these.
90 should be about right. torque 'em halfway first and do them equaly. do you have a good torque wrench?
Just a little tip :wink: re-torque them after a few miles of driving and then again after you wheel it the first time
