I replaced my 35 (had issues) with a JY 8.25… only to find out this one has chatter/growl on Decel. Oh well . I did the brakes, prepped, painted, and put time into this unit so I’m not going to replace it again. I will just to the gears and call it good.
So with that said, anyone have a good shop to do the gears ? I’m in Hope Valley, RI
I am still running 3.55 gears with a 235 tire. Should I bother changing the ratio ? (I do have a small budget)
Thanks for the advice,
Jon
P.S… I know I don’t post much or attend events. I own a small business and am always working. I will try to make time.
If you are still running stock tires (235) keep it at 3.55. If you p[lan on growing to bigger tires than yes re-gear but Bill will advise you what is best for your configuration.
