Rough Country Track Bar
Track bar for an XJ or TJ. It came with my 4.5" lift. It is a little over a year old. It has the stock frame mount with it. $25
is it bent at all, or still in like new shape, if so can you hold it till Friday or saturday?
Nope its in good shape. Had to get a longer one cuz I lifted the truck higher. I even just replaced the tie rod end on it not that long ago. I will hold it for you.
ok thank you. I’ll be in touch with you friday
sent you a text. :smiley:
Hey if pete doesnt want it I will def grab it from you!
i already got it
