Currently i am using the Rough Country quick disconnects. I don’t mind them, however, just DD with minimal 4x4’ing has lead to the thread striping (i suspect).
Any recommendations for a good quick disconnect? JKS, Skyjacker?
JKS
i have JKS on my TJ and they are really worth the cost.
side note, i dont run a front swaybar anymore.
Rustys has a design same as JKS for cheeper
I built a custom 2 piece bar with a pin.
Thanks guys.
I should have trusted my gut when i wanted the JKS, but i got sold on the RC.
Oh well, live and learn.
Make your own
funny that im running the same ones for 4 years and no problems.
I took rear sway links and body side bracket out of a WJ, weld a bolt to the top and use that. only down side is you will need a wrench to loosen and tighten them up when you hit the trails
