Jk Towing
So i Keep reading that the max towing capacity of my Jk is 2k lbs. I might be able to score a 18ft camper pretty cheap that weights 3k. Do you guys think that would be to much for my JK. I would be only using the JK 3 times a year for it. 2 camp and wheels and GTD. It has breaks in the camper, if i added the break controller for my JK would that help? Thanks
It will be fine. I strongly recommend a weight distributing hitch which will all but eliminate sway.
I’ve towed some stupid stuff with my jk. 3k will be a walk in the park
regear would help too
