impact gun
I need to borrow an impact gun, air or electric or cordless. I have an air, but I think it isn’t working well, it won’t loosen a 36mm axle nut. thanks!
i have a socket and a 6ft breaker bar if all else fails
Bob , I got a couple of guns, ya can borrow one , I will not be home till 6pm tonight. I live in cumberland. call me. . AJ
I have one. Could bring it as far as PVD tomorrow. Alternatively, I could meet this evening in the 6-7 timeframe.
[EDIT] Looks like AJ has a simpler solution .
AJ, I will call you. thanks Guys! Derick I had a leverage pipe, all it did was break some of my tools. :laughing:
sounds like its time to get new tools.
let me know if it doesn’t work, i might have some tools we can try to break.
thanks. I do need new tools, such as an impact gun :wink:
bob i got a earthquake one 660ft lbs you can borrow. i’m in coventry 263-7540
I borrowed AJ’s, it didn’t do it. I will F with it tomorrow. :unamused:
You could always grind it off . . . :smiling_imp:
breaker bar, some heat and a tap with a dead blow hammer should be able to take it off. PB blast it in the mean time.
sorry it did not work, I 2nd the soaking it in PB blaster. …AJ
finally got it off, with all the tricks I had.(pb blaster, oxy/acetalyn heat, leverage and the impact gun, going tighten loosen, tighten loosen etc…) it was cross threaded. :unamused: thanks all! AJ, I will bring the gun by
Glad ya finally got it off.
