How To Replace A SYE Oil Seal
I had To Repace The Oil Seal On The SYE on my new tcaase, becasue it was leaking…
Tools Needed:
1/4" Drive Ratchet
13mm Socket
1/2" Drive Ratchet
1 1/8" socket
Stright Blade Screw Driver
Hammer
Loc-tite
Grease
Time:
1 hour
new seal:
here is the seal i ordered for my sye(idk what sye i have), its spec for the teraflex sye…
first i packed the new seal with some grease to hold the spring inplace
then i removed all the bolts holting the drive shaft to the sye output yoke (13mm)
use the 1 1/8" socket to remove the nut that hold the yoke on
pull on the yoke, it should pull off easily
use the screwdriver to pry out the seal, working the srewdrive all the way around the seal
new vs. old
slid on the new seal
use the hammer to ever so lightly tap the seal into the sye, make sure to evenly work all the around the circumfrence of the seal
yay its int!
loc-tite!
slide yoke back on
use socket to start and hand tighten the nut
and tighten really tight, ya dont want it coming back off lol
reinstall drive shaft and your done!
rember to start all the bolts on the drive shaft cv joint be for tightening
and your done
