Gearing question
When I had a ford ranger on the Vin sticker on the door it said what gearing I had. Is this the same for Jeeps? I’m trying to figure out what gearing I have in my 2000 XJ Dana 30/35
There should be a metal tag on both the front and rear diff that will tell you. If you have an automatic transmission chances are that you will have 3:55.
i figured it was a 3.55 but i just want to be 100% before looking in to lockers. thanks!
If you want to be 100% sure pull the cover and read the ring gear.
Make sure when you order your lockers you know how many splines your axles have too.
you could also spin the pinion, and count how many time it takes to rotate the axle once
