front and rear Dana 60s
cj/yj width dana 60, about 59". 4:10 gears, yukon 35 spline alloy shafts. welded (lincoln locker). solid brand cast iron diff cover. no brakes or mounts. $400
the one in the back, cover is not on in the pic
im interested, but ideally i want to run full width
It would be virtually impossible to run full width on the street. 60" is about perfect on an XJ/TJ/ZJ if you want to keep it street legal with commonly available (i.e. reasonably priced) wheels.
The alloys alone will run $400. I’ve started researching my disc brake options for this axle.
I was going to use the Ballistic weld on caliper mounts.
motionoffroad.com/catalog/index. … cts_id=447
I think I will sell the front as well, $500 for the front, $800 for both Chevy, 2 drw hubs 1 srw hub, non-neck down shafts, apart, was going to do the king pins and what not, but…
hmm… i might have to work 4 days of overtime :smiling_imp:
come check 'em out
to be clear, the gears are not apart, just the king pins/outers ttt
$200 for the rear without the cast cover. this week only. my truck needed a tranny. :unamused:
rear sold, keeping the front for the cj. :smiling_imp:
taking the plunge Bob? everyone else is doing it.
I don’t have a choice, got three runs out of an alloy shaft. :unamused: I just dont want to lay it up all summer. :confused:
Warranty?
it was a yukon, sent it back, they are checking the hardness?
Just don’t show them video of you wheeling. :stuck_out_tongue:
c’mon I’m not that bad!
