DYI Hiline TNT Tube Fenders
ok, so i decided that i wanted a little more room to stuff those 35, and to make room for bigger tires down the line.
i started with the drivers side, as it has less accessories to move and remount.
i started by removing all the accessories
heres the goal, to move the fenders up 3" to the next body line
next i removed the 6 bolts holding the fenders on
and
you’ll need to trim the weather striping by 3"… it just pulls off and you cut it with a razor knife
heres a test fit, with the only change to the fender was dilling a new hole 3" lower than the highest hole on the tube side
[img]http://i213.photobucket.com/albums/cc238/YellowJK/TNT%20DYI%20Hiline/DSC04222.jpg[/img
next i cut along the seam of the gusset and the flat stock to mounts to the grill and test fited again
still not close so i notched the tube and test fitted again and it fit good, to i clamped, tacked welded, and finish weled so this is what i got
trimmed the hood on the body line, and drilled new holes for the latches, which i mounted to high
hood line
this what she looks like now
35" tires, 3" lift full stuff, no rub
also i have 8.5" from tire to fender now
thats awesome man!
Nice work!
thanks! lol i installed press on door trim on the cut hood, to protect me from that sharp edge.
now i just have to do the drivers side lol
damn thats some good work
heres some more… from the passenger side
and more detail of how i cut and bent the fenders
heres what it looks like “stock”
and i cut here
then i used my rubber mallet to bend it apart
notched the tube
drilled the new lowered holes
bent it to shape and mounted
mounted a piece of flat stock to weld battery tray supports to
cut the hood
heres where the driver side ended up
all and all, im happier with how the drivers side came out… i’ll probably work on the passengers side at a later date to clean it up.
also i need to switch over to a battery with side posts, as my top post batter is really close to the hood now
