diff housing/carrior
in desperate need of a differential. for 410s putting a locker in and need the housing… dont need spiders or ring gear.
for hp 30
Are you looking for the carrier for 3.73’s and up?
What is wrong with yours? If your carrier is bad everything else would be too.
I have one, but its the numerically lower carrier. IIRC, you are running 4.10’s, correct?
i have a hpd30 housing, but it has the break for the vacuum disco. do not have the carrier
also have a 355 carrier, but dont think that would work for you
