Clunk in rear diff
So got the truck on the ground, everything is all set, drive it out of the garage,
I have a clunk in the rear diff, didn’t have time to investigate today though any ideas?
It’s def the dif? Could it be the drive shaft?
I didn’t get a chance to pull the shaft off, it drfinately seems more related to wheel speed.
:unamused:
not normal locker noises, steady clunking when going straight.
Are you coming to the Oxford or what? I’ll be there at like 6:30-7.
lugs?
I fixed it!
The threads from pinion were still binding against the u-joint,
So I cut them off. I still have some driveline vibrations after adjusting the pinion angle but nowhere as bad as before. I will probably rebuild the driveshaft in the future.
I’m in Atlantic City this weekend.
Sounds better than providence, lol :slight_smile:
