Axle shims for the rear.
Any one have any? I’m thinking 2* will solve my problem. With the new gears installed I’ve been getting some humming past 65MPH. I’m thinking if I just adjust it a little it should go away.
I’m takeing mine out some time next week if you want them 8* tho
6 deg here. Steel
Palmer spring has steel degree shims
Chris I found a set , STEEL ones I bought & did not use. call me , or I can bring yhem to go topless day. AJ
