AW4 dana 35 NP231
DANA 35 3.07 regularly maintained 90$ obo, AW4 runs strong has torque converter. NP231 needs new case its pick in pull status off of the aw4 220 for aw4 40 for internals
is the case cracked? if so where is it cracked? pics?
How many miles on the AW4?
ll need a new output shaft for my 2.5/4.0 swap. not sure what exactly. maybe i should ask google. but ill take the tc if it works…ricky?
Are you trying to use your 4cyl t-case? If so all you need is a 23 spline input shaft for your case.
