Alignment
Does anyone know how to do your own alignment? I did a tierod end with jay today and one of the wheels is pointing to the right alittle. Any helps appreciated
:ugeek:
Setting toe-in: 4x4xplor.com/alignment.html
thanks for the info, right now the driver side tire is straight and the passengers is pointing slightly outward, do you know if this will fix it ?
Yep. Right now the front side of your tires are further apart than the back side. The front side of the tires should be about 1/16"-1/8" closer than the rears. Follow that guide to fix that.
ya, just read that write up. i personally like to strap a board to the outside of each tire and run a measuring tape from one tire to the other in the front and back of the tire. that way i can keep track of how much and which way it moves with each turn.
thanks for the info
